I am buying a used and painted fiberglass hood. Can I paint over the existing paint (red to black) and get a show class finish or what other steps will I need to take..thanks for any help!!
This question should be posted in the Body
Shop, but since we're both here I'll give my input.
Being that the hood is red and you are changing colors, I highly recommend first priming w/ a good 2 part urethane primer.
It is not uncommon for red to bleed thru (older lacquers and enamels especially) the new finish and turning the new finish pink.....even black can turn pink.
The urethane primer will seal it up and prevent this from happening. If you get impatient and choose not to go the primer route, atleast seal w/ an epoxy sealer first.
This problem is not as common as it used to be......but better safe than sorry.
