The brake lights on my 87 camino (daily driver) stopped working...I checked/tested the fuse and it's not blown and I have voltage to the brake light switch plug..
Also have power to the l/blue and gray wires (coming out of the switch)when the switch is activated...
The switch itself, Has 2 seperate plugs to it ...one plug has 3 wires ,L/blue, red and L/grey and looks to be 16 gauge...The other plug has 2 wires (20-24 gauge?)..
The 3 wire plug as mentioned above I believe to be for the brake lights ...BUT can anybody tell me what the smaller gauge 2 wire plug is for ??? Could it be part of the problem ?
I did notice that the fuse for the brakes is also for the emergency flashers which work fine along with the turn signals ....JUST NO BRAKE LIGHTS !!!!
I am not good at the wiring stuff so Any sugestions would be greatly appreciated ...
I need to get her back on road . the 3/4 ton 4x is sucking me dry as a commuter rig ....THANKS , Kevin
