Gold Founding Member
Put my dash in last night and hooking up the wires. Not sure what these are for. This is a 70 SS no A/C no Gauges
The 12g pink and 14g ppl according to wire manual go to the dir signal flasher - but isn't that on the fuse box already?
The other plugs are
What looks to 18g orange plug - have no idea - it's not the cigarette lighter as that is plugged in already
Then there is the what looks to be 18g black and 16g brown - have no idea what this one is for.
Any help would ber great. See link to pic.
Thks
Rich
http://my70ss.homestead.com/files/Restoration_081.jpg
Just going from memory I would guess the extra orange wire is for the optional clock.
You have two flashers - one for hazard warning and turn signals. The one on the fuse box is hazard warning.
Not sure on the brown/black, where is it located?
Some harnesses have wiring for A/C and non A/C. If your car had A/C I think the brown/black would power the A/C panel and you have a separate harness for the fan/resistor connections.
Discussion Starter #3
Steve,
Sounds correct - I recall an orange to the clock if there was one and it is coming out of the harness by the clock so the orange is mopre then likely that.
I forgot there were two flashers, thks - that one is solved.
The brown black I was considering the same - the harness came out of a 70 Monte - but not sure if it had air or not. Either way though I don't think an A/C and non A/C dash harness are different, only the forward or engine harnesses would be.
Thks
Rich
Rich
A/C and non A/C harnesses are different. The one you have is for an A/C car. The brown wire is power for the A/C harness. The black wire, if you look close I think you will find a pink stripe, is power to the TCS circuit. If you can still read the fuse identification the top right fuse is marked A/C TCS.
