I acquired this GM Delco radio a while back. It is an am/fm unit with multiplexer. It looks to be late 60's vintage. The service model number is 04BFM1. I'd like to know what GM application this radio would originally been installed in. Thanks.
Have you checked out Coppertop's Radio Tech section? Probably find the answer there. It contains decoding information.
04BFM1
0 = 1970
4 = Div of GM ?? It's not chevy, pont, or olds. Maybe it's a Buick?
B = Body (full size)
FM = AM/FM
1 = 1st series
My 70SS
The radio tech was leading me in that direction. Either Buick or Caddy. What confused me was the it seems to be a 70 but it does have the multiplexer mounted on top of the case. The multiplexer has the same service ID# tag on it. The radio tech indicated that the separate multiplexer was eliminated in 70. I can take a picture and post it here if this forum allows images.
Hey guys,
Okay here's the scoop:
04BFM1
0 = 1970
4 = Buick Division of GM
B = Full-size (LeSabre, etc)
FM = FM-stereo receiver
1 = first electronic design
****YES this radio needs it's little "pal" the hidden stereo multiplex box to work properly******
1970 was the first year for the 1 piece stereo unit--but not for all GM products!
Chevrolet division really got the cream-of-the-crop from Delco Radio. But this wasn't the only reason for the 1-piece units. A lot of vehicle's designs dictated what kind of equipment was used. Sometimes it was absolutely necessary to "split" the stereo equipment due to internal room in the dashboard.
For example, I worked on a '70 Cutlass 4-4-2 Convertible, it had a stereo radio I repaired. This also used a separate multiplex adapter--the answer was obvious--man what a cramped dash!!
The multiplex box was mounted above the glove compartment to spread out the electronics.
By right, the multiplex box should have the model #:
04BMP1, (the MP=multiplex adapter) but I suppose there are always exceptions to the rule. Just be thankful you have both parts, most people toss the box, or forget it in a junked/wrecked vehicle
Hope that helps.
But Coppertop, Did you happen to check out the instrument cluster on the Cutlass?
Each gauge can be removed individually without removing the whole dash
But I'll agree its tight behind the radio
Philip Mullaly
72 TPI El Camino
"Hey Ya'll watch this...."
