1 - 14 of 14 Posts
This code was found on the axle tube: cw 7 129 b is the code (pass axle tube) any help appreciated.
I am no expert but I think this is correct CW = 3:31 Ratio 7 = 1967 12 = December 9 = 9th day b = Buffalo Plant
So that might be a for a `68 car then no?
The year is not shown in the stamp. You must have misread the 7.
(MM/DD) used thru '70.
The year is shown in the center section casting date. Small raised
code on one of the axle support gussets. Look facing the cover opening at the 5 or 7 O'clock position.
Letter for month and numbers for day and last digit of year. Looks similar to this:
(MM/DD)
Ok,i`ll get the casting #s off the housing,the rear is suppost to be a `67 rear i just wanna make sure its not 68-72 rear,i bought one a few years back with the 7 casted where you show in the pic and it turned out it was the wider 68-72 rear.
1 - 14 of 14 Posts
