So I wan the 67 chevelle about two days ago, No prob... I was gonna cruse tonight when I noticed my brake/rear running lights were not working(no light). Tried my blinker, worked perfect, so I know there is not a short at the tail lights. I also have two new bulbs and one new bulb socket. I checked the fuse and no power going to it(or from it). Took of the fuse panel to check for shorts behind and tested the wires, no power. So(this it were it gets odd), I then proceeded to run a fused HOT jumper to the fuse panel to test. Running lights work and my dash lights turned on(I didn't realize it was off untill this point). Mind you blinkers, head light and front blinkers work this whole time. I went to test my brake light and instead if getting brighter, they dim when i hit the brake then slowly get brighter(as bright as the running light. I also tested my brake pedal switch, seem perfect.
What am I missing? I cant get to my ignition switch without taking my dash apart, and even with jumped power, no brake light. I know my charging sys is perfect and battery is good(dash does not dim when I hit the brake.
PLEASE help, I just got back on the road after 5 years of work on her. Thanks if advance...
Greg
Greg
