Need help.. Swapped a good 93' 350 Caprice Wagon motor into an 89' 4x4 Half ton Pickup. The engine has a deep hollow noise after the first start up. All of the sensors were used from the original engine. The chip is for a 305/350 ci. Engine runs good but still makes internal noise. Almost sounds like a rod. Oil pressure is good. Can't hear it while driving but once you stop and idle you can hear it again. Any thoughts? Many hours invested and near the end of our wits. Already tried posting in troubleshooting.
My concern at this point is if the dist. is off enough will the computer compensate and advance/retard the ignition and cause the knock?
