I am installing this weekend a Pertronix Ignitor II with their Flame Thrower coil for the reliability of electronic ignition while keeping a factory look (except for the extra wire) their Flame Thrower coil and will have the distributor out to do so. My quandary is: My current idle timing is at 18 degrees BTDC at 900 RPM. Any less advanced or lower idle speed and the car labors to run. The carb has recently been completely rebuilt, the idle mixture screws are at 1.5 turns out and have not adjusted them yet for leanness. It does not have a radical cam. My distributor position is turned more clockwise than ones I have seen on similar cars. When at 0 on the timing mark plate, I am pretty much at TDC (using the straw in plug hole #1 looking for change in movement method). Could my distributor be one tooth to far clockwise? From what I have read – the physical position of the dist doesn’t matter as much as is the rotor hitting the right plug at the right time. I’d like to get the dist back to a factory position with factory timing (4 degrees BTDC) or close. I feel I have several things going on here and need to know what makes sense and what order do I need to take to get things right. Maybe I need a timing 101 or perhaps the new electronic ignition will help me and should just put the distributor back in the current position and start from there? Any thoughts on my situation?
Engine Facts:
396 / L34, factory Holley List # 3419 (just rebuilt), factory 4 spd Munice, no PS, PB or AC, all new vacuum lines and PCV components.
Thank you,
Engine Facts:
Thank you,
