I'm going to install a kill switch to my MSD ignition. Can i use any switch and any wire, or should they allow a certain amount of amperage to run through it..i just don't want the car to burn down
As you may or may not be aware, to kill the MSD unit (I have a 6A) all you have to do is ground out the white wire. For my application, the white wire was unused and can be easily extracted from the MSD wiring bundle.) I just installed a simple heavy-duty toggle switch (radio shack) between the white wire and a good ground. (This will allow the engine to turn over but never start - a big PITA if you forget that you have the switch on!) The white wire itself is only about 18-20 guage standard automotive wire. I used a slighty thicker gauge to connect to ground. Hope this helps.
Another approach is to break the 12 volt wire that energizes the MSD box. That wire is a 12 volt switched wire and w/o juice there the engine cannot start. I know this works cause I disconnected the one on my Vette when fooling with the distributor cover. Lots of cranking but no fire in the hole.
This is a very low voltage wire and it only signals the box that the ignition is on. I am NOT talking about the 12 volt wire that goes from the battery positive to the box. Leave that alone. That wire actually operates the electronics inside the MSD box.
