I'm going to be building a BB 427 over the next yr. to yr. and a half. I'd like to get your thoughts on what I have in mind for this engine. I already have the block, crank and heads. I plan on this engine being high reeving, power being in the 3000 to 8000 RPM range--Not sure if I'm going to run a single 4 on it or Dual Quads, so far I'm Leaning towards the Dual Quads, they would be set up progressive.
Drive Train & Suspension
Transmission--TKO 600 W/.64 overdrive
Bell housing--McLoed sfi
Flywheel--Centerforce Steel sfi
Clutch--Centerforce DFX sfi
Rear End--12 Bolt w/Detroit Trutrack
Gears--Richmond 3.55 ratio
Rear suspension--Global West upper & lowers w/Del-A-Lum Bushings
Front Suspension--Global West Del-A-Lum bushings on stock A-Arms
Springs--Global West, Lowered 1" front & rear w/air bags in rear springs
Engine
Block--Mark IV 454 .060 over
Main Bearings--4 Bolt Splayed Centers, 4 Bolt Standard on both ends
Heads--RHS Alum. Retangle Port, 320 Runners, 119cc Chambers
Crank-- 3.75" Stroke GM forged steel Nitrided knife edged
Pistons--SRP 11:1 compression
Rods--Eagle H-Beam Floating
Cam--Isy Solid Roller .750 lift
Lifters--Isky Red Zone Solid Roller
Pushrods--3/8" Chromoly
Roller Rockers--Comp Cams Pro Magnum
Valve springs--Comp Cams Beehive springs
Main Studs--ARP
Head Studs--ARP
Rocker Studs--ARP
Rod bolts--ARP
Bearings--Clevite
Rings--Plasma
Exhaust--Full length headers w/3" or 3 1/2" w/X crossover--run to rear
* This engine will go in my 71 Elky that now has a 402 (396)
This setup is 99% for the street, I like the 3.75" crank for the fast,high reeving. Its to run only on pump gas
Engine
Main Studs--ARP
Head Studs--ARP
Rocker Studs--ARP
Rod bolts--ARP
Bearings--Clevite
Rings--Plasma
