Putting in the warning light gauges as part of a sweep speedo change...
On either side of the speedo, at the bottom, there are two warning lights. One has a green lens on it, one is entirely missing a lens and appears to have no provisions for one. What are these lights for and what color should the loeft hand one be? Brake light? High beam?
Mystified...
:confused: :confused: :confused:
I'm assuming it's a 70. The right lens is the bright light indicator, should be blue. The left is the brake indicator, should be red with BRAKE on it. The brake lens is not attached to the cluster it is held in place on the dash plastic.
Elree, I think you got it.
Sorry - it IS a '70...
The turn signals are located at the top and the two at the bottom are the mystery. The right hand one is blue, so yes, I assume that is the hi-beams, but the other has no cover and no provisions for one as you suggest. The round gauges are standard warning light-style and do not have the red "brake" lens, but certainly could...
So the next inevitable question is where to find one of these. Seems not to many sources to find these pieces...
