I just bought a new tank with a competition engineering rear weld on sump with 1/2npt fittings that i had welded on. I have a BG220hr fuel pump system with a bg5000 fuel filter. The system is setup with a return also. When driving I constantly end up sucking air through the fuel pump and the only way to get it to suck gas again is to remove the fuel supply line at the carb, blow into it until I hear bubbles in the tank, turn the fuel pump on for a second with the line disconnected, then screw it back onto the rest of the fuel system. I have a return setup on the system that returns fuel right next the supply...could that have something to do with it? Its frustrating after i bought the new tank and sump as a way to solve all my fuel problems, but only to have more problems after I got it installed.
You should not have your return right next the supply line. I converted my orginal sending until to 1/2" and used that as my return. (this is on my 56 belair). You are causing the fuel to be stirred up (for a lack of a better word) which is causing sir to get into the fuel lines. Someone can probably explain it better. But I have always been told that the return should come in the top of the tank. Hope this helps.
Tom
well i pulled the tank and drilled a oblong 1/2" hole on the top by the fuel sender so i could snake through a peice of 1/2" aluminum fuel line. I used JB weld all around it on both sides and while the tank was out covered all the welds on the tank from where the sump was welded on to just be safe. Going to put it back in tommorow after the JB weld hardens and hope it works.
