1 - 9 of 9 Posts
I had big valves installed in a pair of big block closed chambered heads. While installing the seats a couple of the water jackets were hit. The builder said he sent them out to get repaired with ceramic and pressure tested. Are these heads still good?
Please let me know,
Gold Founding Member
K-W ceramic/metallic sealer worked on my Olds. Still holding after more than a year.
I should be ok I had one like that
Question how much did that cost cause I got a craked head and builder says it cant be welded and he didnt know of any way to fix it it is in the seat where the water jaket is cause it dropped a valve.
Have never heard of it either.
What casting number was it Dave?
Dan
The heads are oval port 820. From what I have heard from other sources is that the ceramic seal won't hold up to the pounding of a valve seat and will begin to leak. I'm checking for more info.
Thanks guys.
Dave
1 - 9 of 9 Posts
