1 - 2 of 2 Posts
I got a jump yesterday, started the car this morning, completed a little bit of work, tried to start the car, now it won't start. I get clicking noise, dome light comes on but nothing else. I have a 14 gauge wire from the neg side where the fender/radiator support bracket is, this not enough ground? Thanks for the help
Well, sounds like a dead battery. Try jumping the car again and meauring the battery terminals when it's idling. You should see around 13.5 volts to 14.2 volts. That should tell you if the alternator is working.
An alternator is not a battery charger. It won't charge a dead battery. Need to charge the battery with a battery charger and see if it stays up.
1 - 2 of 2 Posts
