1 - 13 of 13 Posts
1966 Chevelle SS396
I'm assuming they're not all the same. New to Muncies, so go easy on me ... :)
A guy has a 3851325 Muncie for sale, comes with shatter proof bellhousing and Hurst shifter and linkage. No tailshaft housing. $500. Says it has maybe 2K miles since a rebuild.
Not able to count the splines/grooves yet, cuz it's still hooked up to a transfer case. But he says he will get it apart and check.
That shows to be a 64/65 M-20, which is close to what I'm looking for.
Are tailshaft housings easy to come by for that case? Price range? Is that a decent price for one of those?
Thanks a lot! :thumbsup:
WITH the bellhousing and shifter, but missing thetailshaft, $500 sounds decent.... I'd make sure everything is okay though...
Not a bad price I would say. That being said I would stay away from the 325 cases if you are going to beat on the car. I'd try and find an 010 case. That would be correct for a '66, if that's what you are after. Tail housings are pretty easy to come by. I would guess the shifter rods are different. I'm not sure how the shifters mount on those 4x4 transmissions.
1966 Chevelle SS396
Thanks, guys. :D
The 7/8 or 1" bore is the countershaft bore, correct?
While I would like to find a '66 M-20 just because, it isn't a big priority, since the car came with a 'glide and it won't be correct anyway. So, not a big deal on the year ...
I'm not planning on doing any speed-shifting or the like, but I do want a trans that will last. I may hit the lotto and put a 540 in it someday. l:)
Avoid the 7/8" countershaft Muncies like the plague.
2k miles on a rebuild, but the tailshaft housing is now MIA? :confused:
Since the car didn't come with a 4 speed anyway, I would be less concerned with date codes & focus more on strength & reliability. My opinion is pass on this deal quickly & hold out for a later HD Muncie with a 26 spline input / 32 spline output.
Pete, from what I gathered this was hooked up to a transfer case. Of course now that I think about it the main shaft would need to be changed. I prefer the 26/32 set up transmissions as well. That's what both Chevelles are set up for.
I'll make you a hell of a deal on a 1965 M21 1/2. :D
Not really. I need a clunker M22 I can beat on so I can save my nice legitimate M22. ;)
1966 Chevelle SS396
Didn't you have a later M-20 recently?
I had a '67 M-20 that I sold. I also had a 26 spline M20 input gear when I was going to build an M20 for my car. I ended up building the M22 instead. Thus the M21 1/2 comment.
1 - 13 of 13 Posts
