for years of experience and customer satisfaction check out below:I have a Muncie M21 that I am wanting to have rebuilt. Do any of you recommend someone that is honest and does outstanding work with years of experience? If so please reply or send me a message. Thanks
I think Paul Cangialosi has a video on rebuilding one and also sells a book on how toWith just a couple special tools you can replace the seal bearings and synchro's your self. If you want to step up go to an aftermarket m22 m23 or n24.
I agree the overdrive trans is the way to go. However in addition to altering the driveshaft and cross member position most overdrive transmissions will require a new yoke and the new clutch due to a different number of splines than a muncie.I don't know what any of the reputable guys charge to rebuild a Muncie... but compared whatever that would cost plus shipping both ways, I can't imagine that option 2 would cost significantly more $$, and option 3 might only be somewhat more $$. Just something to think about![]()
All good points. Not sure if the new Tremec TKX requires a different yoke or not (the rep didn't mention it and I didn't think to ask) but he did say it needs a 26 spline clutch. So he may or may not need a different clutch, but I didn't bother mentioning a clutch because it's probably a given to replace it anyways when the trans is coming out for a rebuild. I'm sure there are other small parts that will be needed too like a shifter handle, boot, whatever modifications you'd need to do to the wiring for the reverse lights, not sure if the speedometer cable bolts right in or if you need some kind of adapter, etc.I agree the overdrive trans is the way to go. However in addition to altering the driveshaft and cross member position most overdrive transmissions will require a new yoke and the new clutch due to a different number of splines than a muncie.
I always recommend that when someone is considering a gear change that they use an rpm calculator and figure out what rpm they will be running with the new gears then go out and run that rpm with their current set up and see how it feels.
For instance at one point I was considering a new M23 and changing my rear end ratio to a 3:08. Well I figured out that with those items I would be turning 2650 rpm at 65 mph. So I went out and ran my car at 2650 rpm on a quiet stretch of highway. What I discovered was at that rpm the exhaust was louder than I would like to listen to for anything over 10 minutes. With my overdrive I turn 2200 rpm at 70 mph and the exhaust report is much more agreeable.
Check out the link below for specs for the M22Z. There are one or two other variants too, I can't recall the ratios of the other ones off the top of my head but I think the M22Z has the most aggressive gearing. Says they're sold out, I think these were kind of tough to get your hands on even before Covid so hopefully they're not impossible to get now.Timely post. I'm considering refreshing my M20 since it's out of the car. Thought about sending it to Jody, but the idea of 'doing it myself' is quite appealing and I did pick up Paul's book. And since it's the original, I wouldn't have to worry about some freight company losing it...
Curious about the 1st & 2nd gear mods -- can anyone offer a bit more explanation? My rear end gears are 3.31 and I'm satisfied with the RPMs on the freeway (I don't drive over 67 anyway...)
OP -- if this is stomping on your thread, apologies and I'd be happy to start a new one.
Got to be politically correct nowadays or someone's feelings get hurtI dont know if Nate has any in the house, try here: Auto Gear Equipment | Custom gearboxes | Muncie and Tremec Transmissions
The Z gears start with a 2.98:1 1st gear ratio, so as said, your "diggin' " gears are like a rear axle ratio bump. I use the 23Z gears. You think M22 "rockcrushers" are loud. Aint got nothin' on the M23Z's "DIVCO truck" gears! M22Z are helix and quiet I'd imagine.
Anyway, call [email protected], tell 'em we sent ya for some info. He'd be happy to chat. Whether you , or Jody or anyone else rebuilds the unit, you can swap out gears.
Dang; the site edited my Italian gear joke, which was based on a old Italian helicopter joke! Mingya, even my old Catholic school buddies allow me a dumb joke once in a while!![]()
Thanks. Looks like the 10 spline might be available...Check out the link below for specs for the M22Z. There are one or two other variants too, I can't recall the ratios of the other ones off the top of my head but I think the M22Z has the most aggressive gearing. Says they're sold out, I think these were kind of tough to get your hands on even before Covid so hopefully they're not impossible to get now.
Muncie M22Z Gear Set - Made in Italy (5speeds.com)
