Wolf,
First of all, to check externally for an M-22, you need to find the stamped date code which is a combination of letters-numbers on the main case (usually at the rear side or top of the main case). A Muncie date code will start with a P-for Muncie, a number for the year, such as a 1 for your 71, then a letter for the month, a number for the day of the month, AND LAST, A LETTER, (starting in 68) A,B or C. A for M-20, B for M-21 and C for M-22. As an example, let's say your 71 M-22 was made on Mar 22, 1971. The date code for it would be P1C22C. Muncie-71-Mar-22-M22. That last C designates M-22 and it is the only external way to tell if it is (or was) an M-22. Now, if at sometime in its life it broke and gears were too expensive to replace it may have been converted to an M-20 or M-21. SO, THE ONLY WAY TO KNOW FOR SURE IF A MUNCIE IS AN M-22 IS TO OPEN IT UP AND LOOK AT THE ANGLE OF THE GEAR TEETH. Go to Gearzone for a good comparison of the difference.
To identify a Muncie, look at the side cover. It has 7 bolts and the top center bolt hole is raised above the straight surface of the top of the side cover. A Borg Warner Super T-10 has 9 bolts and the top edge of the side cover is straight.
ALL 63-70 Muncies (except '70 M-22)had a 10 spline input and a 27 spline (turbo 350 size) output shaft. The 1970 only M-22 and ALL 71-74 Muncies had the fine 26 spline input and big 32 spline (turbo 400 size) output shaft. DO NOT LET ANYONE CONVINCE YOU THAT A FINE SPLINE INPUT OR A LARGE OUT PUT SHAFT MEANS IT IS AN M-22! First, look for the "C" at the end of the date code. If there is a C, then the only way to verify is to remove the side cover as above. If there is no C in the date code or it has an A or B, then it is unlikely that anyone has converted an M-20 or 21 to an M-22 (except me).
Some Muncies do and some do not have a ring(s) around the input splines.
GENERALLY SPEAKING:
63-65 M20-no ring
63-74 M21-1 ring
66-74 M20-2 rings
M22-no rings
Any GM replacement input shaft-no rings(?)
Problems: If it ain't broke, don't fix it. An M-22 is supposed to whine louder than an M-20-21.
If it grinds or doesn't slip into gear easily, it probably needs new brass syncro rings.
If it leaks oil around the front of the cluster shaft, the hole in the case is oversize (worn) and needs to be repaired with a bushing.
If it buzzes and vibrates through the shifter handle going down the road, the rear main bearing is probably bad.
If it goes click click click, there is probably a (some) broken teeth.
If the whine is even, it doesn't leak oil, shifts into all the gears easy (while driving), doesn't jump out of gear (accelerating or decelerating or downshifting) and doesn't buzz or vibrate through the shifter handle, LEAVE IT ALONE! But, if it does any of the above and none of the internal parts seem to be broken, then it is probably worth rebuilding.
Tom Parsons
[This message has been edited by DZAUTO (edited 11-16-99).]
