Trying to rebuild my Muncie transmission, and am having more end play (front-to-back) in the countershaft than I expected. I don’t have a dial, but would figure something around .020”.
How tight should the countershaft be? Should I shim it? And if so, what would I use to shim it?
On a second note, I’m also having issues with the countershaft lining up with the main shaft. Front to back, there is a .070” shift from the main gear lining up to the corresponding counter gear. I can’t seem to find any way to adjust that? I did find a thin (~.005”) shim in front of the input shaft gear (4th).
Thanks, Neal
Thanks, Neal
