i have a 68ss. it has stock size wheel wells and i dont want to cut the inner lip. im looking for a second set of tires to take down to the track once in a while. im running a 402 with a four speed and 373 gears.
On my 68 with un-cut fender lips, I have 10x29 Goodyear slicks mounted on Centerline 15x8.5" auto drags with 4 7/8" back spacing. No interference anywhere.
I run stock 7 and 8 inch rally wheels, I like the 275/60r15 bfg drag radials. I also get some cheap roundy roundslicks when they get tired of them and use them up, They throw them away and they fit great. I run a 69ss396 car with aftermarket quarter panels so my lip is 3/4" larger so i have less room
MT 3754 will fit with 15x8, 4.5 bs. I see a lot of people running these at the track with basically street cars. It's also a DOT slick so you can cruise around town if you wanted to, without having to swap wheels, etc.
http://www.summitracing.com/parts/MTT-3754/
Good height tire with the 3.73s you are running.
The 3054 is a straight slick, and it's a little shorter still, if you don't want the DOT's.
I don't run tubes and neither do most guys I know.
