1 - 18 of 18 Posts
Summit msd system..is there a light that will pley with this system thats not $300+ bux?
Tired of guessing where this thing sits, being cheap I guess.
OK, well, lots of bad info floating around on "Dial Back" timing lights.
Dial back is a feature to rectify electronic fuel injection system computer timing functions, that HAVE COMPUTER COMPUTATION LAG TIMES, NOT FOR ANALOG SYSTEMS WITH MECHANICAL, VACUUM ADVANCES, as analog systems have NO COMPUTER LAG TO CORRECT.
And, in the 4 plus decades I have been working on cars, carbs, ignition systems, I have NEVER seen a computer lag in an analog system, EVER, so, all that hooey about "Dial Back works on all systems", is just plain pure horse hockey.
So, for your MSD sysem, if it is NOT a digital tming setup, NO DIAL BACK< put a timing tape on the dampener and leave the dial baco OFF. IF it is a digital timing system inside the MSD box, and the distributor is fully "locked out", fine, dial back is for YOU.
Discussion Starter #3
one I have now is a crafstman, never use the dial back its at 0. Mark is all over the place....dances some at lower rpm and as it goes up the marks move around more. Cam enplay is good, guessing its the light. Cant get a good read or guess on it.
dist is not locked out, hear some day definitely, others say it will knock..who knows.
stick, low gears 82 deg overlap has some compression. Strip car on the st
A MSD-technician in the MSD-Forum stated somewhere, that with Capacitive-Discharge systems, no dial-back timing light should be used, because - as Dave states - it cannot be guaranteed that it wont show a wrong value, due to the high currents in the wires, "confusing" the timing light..
With non Capacitive-Discharge Systems, thats another story..
I have this
Works with msd decent price self-powered.
Bill
Keep the clamp on pick up away from other plug wires and separate the plug wire that you are on away from the other wires. It takes very little signal to trigger the timing light. You are seeing signal from another wire nearest the pickup or other wires that are running parallel to the wire that you are on.
I have both a Snap On digital Light and an MSD Light. I use the MSD on my 7720/7730 powered ignition. I like the MSD light pretty well. Good investment.
Still using a ACTRON dial back, w/o dialing it back any. No issue with MSD.
PS, I checked the Actron with my buddy's high end digital Snap on. A very nice light but spendy.
Super Moderator
I have been using a 30 year old SunPro by Actron dial back timing light with my MSD ignition setup for years without any issues.
:cool: Just my 2 cents: I had a similar "timing light issue." I tried a second light and still had the same problem. By that point I guessed and picked up an inexpensive DISTRIBUTOR at the local auto parts store. The new dizzy solved my problem. My old timing light didn't lie, it was my old dizzy that needed a rebuild.
With any multi spark discharge ignition, some lights pick up the spark at different times, making it appear something is wrong. Run it up to 3000 rpm where the sparks are closer together and that goes away.
Really...very interesting, but.........hilarious, VERY HILARIOUS.
BTW, if you run cheap wires, expect RF interference between spark events for different cylindrs, and also expect the ignition system to overload frm trying to fire multiple spark plugs at once, which timing lights, especially when dial-back is on, won't show.
Enjoy the comedy of it all.
I used a regular Craftsman timing light for years when I was running an MSD box. It worked perfectly. Model 2134:
Pay attention to the listings, because come of them are being sold with no leads. However, the prices have gotten significantly higher (good thing I still have 3 working ones).
Discussion Starter #18
Ill try #6,,,,mark still moves around at 3k, tried different wires. It better NOT be the distributor sunk too much in this pos already. Doesnt miss at all, runs smooth as silk?
1 - 18 of 18 Posts
