I am getting ready to install a msd style box (firewall), and was thinking about the install hardware. Are sheet metal screws enough? Toggle bolts? Any info is appreciated.
Sheet metal screws will work. I had a buddy that nutted stove bolts from the back side, making studs that he could slip the box over and then another set of nuts to hold it down - pretty slick and more "removable" than sheet metal screws.
Use the rubber mounts or something to cut down on the vibration or the box will fail sooner than later.....
