I have a 350 with a 750 rodchester quadrajet. Well I have been having a problem with it fouling plugs. It has ran rich for a while despite leaning the carb's mixture screws out. My question is if I put a multi spark ignition system on it will that help my running rich and in turn helping my plug fouling? I will post my next question in the carb section, it will be about rejetting the quadrajet.
Discussion Starter · #2 ·
Don't worry about answering this question because I just bought a mallery hi fire ignition box. So I will install it and see if it helps.
Super Moderator
Pudgy,
If it does help, you will just be covering up a problem. Even the stock point type ignition should work fine. I suggest that you actually fix whatever problem is causing the plug fouling first.
