I lost a couple of the little sleeves that fit in the fender and help hold the emblems in place. As the emblem goes in the fender, it expands this little sleeve and holds it in place.
What are these things actually called and any idea where I can pick some up?
It probably doesn't matter - this is for a 69.
You may be thinking of the small brass inserts that go into the fender , Then the trim just pushes into them. Do you remember,, Speed Nuts or Brass Inserts?
Bob
