Hey Guys,
I am trying to tune my 461 motor and am at my witts end. I'm running an 850 Demon Carb and can't get the carb to lean out. No matter what I do, it runs rich as all hell. Here are the problems I'm having and I would appreciate any help / suggestions you can offer.
Set-up: 461 BBC, Performer RPM manifold, 850 Demon Carb, MSD ignition, Oval ports with 225/188 valves, Super Comp Headers, AC Delco 43 plugs) Timing: 37 degrees total and 16 inital.
Issues:
* Backfires out of the passanger side header when it comes down off of throttle.
* Black soot along the entire exhaust ports by the head.
* Runs totally fat no matter how much I turn the needle and seat down
* It idles for a little while then it loads up and wants to shut down unless I keep giving it gas
* After the motor sits for a few mins. it is hard to get it started (almost like the carb is leaking into the motor and flooding)
* Fouling the plugs
* Gas dripping near the throttle shaft
My question is should I just buy a new carb and which one and size for my set-up.
Thanks!
Issues:
* Fouling the plugs
Thanks!
