1 - 2 of 2 Posts
I'm installing the motor back in and was wondering if it's wise to do this with a munice hooked to a Lakewood bell housing? The dowel pins are "0" offset, bell housing was centered and Lakewood washers welded in place to keep those pins. I don't know if there's a chance of throwing off the aligment due to the weight pulling on the bell.
Thanks R.J.
Should be no problem installing both at the same time. The trans weight won't make any difference as long as everything is bolted up tight.
1 - 2 of 2 Posts
