Will my motor mounts from my 307 work with my 350 I'm getting? This is for a 68 Malibu.
thanks
68 Chevelle Malibu four door - under construction.
Tubbed 68 Chevelle something. One day a race car.
Yes, same block for the most part. You may have the parts store guy tell you they have different part numbers but they will work.
70 and 72 Chevelle
ACES # 4051 MCC # 448
TC # 1549 81/70 Cruisers
Yes, just use the 307 engine mounts on the 350. The 307/350 engine mounts are different, but as long as you keep the engine and frame mounts matched they work fine.
Dave
70 chevelle ss396 conv
66 chevelle ss396 hdp/conv
72 chevelle
55/57/61 chevies
TC member #493
Never forget Earnhardt!
both of you are right. if the frame mounts are 307, not only will the 307 motor mounts fit your 350 , but you need to put 307 motor mounts on your 350. the 350 motor mounts are not as wide and will not fit over the 307 frame mounts. 307 is the only one that is diferent from the rest of the v8's. 350 thru 454 are the same.
1970 Chevelle 454 Wagons haul A$$ in style! "The Chopped Suburban". to see some goto
www.EINSTYN.com FO_FDYFO = four-fifty four! TC#1460, VCEA#2
[This message has been edited by FO_FDYFO (edited 01-15-2002).]
