I've used the chain to head method but am considering a x-mas present of the carb/manifold lifting brkt.Never used one but have seen them used.Any real dangers or negatives with useing the carb type brkt.??
Are they good to use with engine/tranny removals or just engine lifting???Comments please??!!!!
Rick
I made a bracket like the one I think you are talking about. It bolts on to the manifold in place of the carb. I don't even know where it is because I haven't used it since a friend of mine got one of those engine tilters. The manifold bracket works fine for lifting just the engine, but it is impossible to change the angle once you have the engine's weight on it. That crank tilter thing works so slick, it's easily worth buying one even after the first use.
Steve
72 Chevelle SS402/4sp
Go with the tilter especially if your going to be installing an engine with the transmission attached. They work great. Lets you do the job by yourself too.
Bob (Pa.)
1963 Impala 283
1966 Chevelle SS 409
1969 Malibu 307
1972 Malibu 307
1969 Chevy stepside 350
Bob's 409 Chevy Page
silverstone.fortunecity.com/tvr/246/bob_s_409_chevy_page_index.html
I agree, The tilter is the way to go, but if you are like me and pinching the old pennies. I have doen it quite a few times without it with the tranny attached. It takes two people though. but can be done. I have done it myself and just used a come a long to tilt things as needed. A poor man has poor ways. And about the bracket it works fine. Slime
Steve
Slime- been there done that. I didn't say I bought a tilter, just borrow it. I put a BB in a car without a tilter, and the transmission was installed. I used a cherry picker for most of the weight, and a come along for the tailstock of the tranny to tilt the engine. Oh yeah, by myself! It just takes some patience.
Just a word of caution though. If you are going to use one of the manifold brackets, make sure you use as long of bolts as you can, especially with an aluminum intake! take some longer bolts and grind them down or shim them with washers. A friend of mine used my bracket to hoist a 440 mopar into his car, with a 4sp bolted to the motor (mopar trannies are heavier than chevys) He bolted it to the aluminum intake with the carb studs! It let go! Wasn't pretty, but could have been worse! Be careful!
Steve
[This message has been edited by SSteve L (edited 11-26-99).]
