1 - 20 of 25 Posts
It's a 1970 Chevelle with a 454. It has a factory type fuel pump (not electric). When I turn the ignition off it keeps on running for about 3 seconds and than shuts down. It seems to shut down slower than normal, not like before when it was instant. Any suggestions would be greatly appreciated.
Thanks, John
I doubt this is an electrical problem but I could be wrong. Back in the day, this was caused by hot spots in the combustion chambers from carbon deposits still hot enough to ignite fuel without a spark from the spark plugs. Poor quality fuel was the suspected cause.
So, please don't "ignite the night time petroleum" too much here trying to over think it or solve it. Simply buy higher quality (not necessarily higher octane) Top Tier fuels that have a good detergent additive package blended in - I'm a Shell, Chevron, Exon Mobil buyer whenever possible. I also periodically run a jug of Chevron Techron, BG 44 Platinum, AC Delco X66P or anything containing detergents from Berryman's in my tank at very high concentrations to keep my cylinders clean. Yes, call me weird here and I'm OK with that. Very high concentration = whole bottle poured in at a third of a tank of fuel remaining.
And please note - your combustion chambers did not get like this overnight and my offered solutions here won't work overnight either. This will take months of running these high concentrations of cleansers and good fuel through your engine to make progress but at least your are solving the problem passively and not tearing into your engine.
Rick
Thanks, John
Last time ignition timing was checked?
If it basically 'stops running' but 'chugs' along for a bit, that's 'dieseling'. There is enough residual heat/compression in the combustion chamber to ignite the fuel w/o a spark. The simple causes are too low octane gas, or too much initial ignition timing advance, or both.
If it actually 'runs' (not chugging) there may be a problem with the ignition switch.
Pete
If truly dieseling , as others have said the primary idle speed is set to high. If you cannot back the idle speed screw down enough to remedy the run on after key has been switched off, you will have to add an idle stop solenoid to allow the primaries to close more completely.
IF the ignition timing is set correctly, initial and vacuum advance set up correctly, the carb throttle plates won't be open too far, and the idle transfer slots won't be feeding the increased quantity of air at idle.
Please let us know a few things, if possible:
Initial timing:
Vacuum advance timing at idle (full manifold vacuum port):
Idle speed RPM:
Discussion Starter · #14 ·
Thank you for all the responses. Its not dieseling it continues to run normally, I do use 93 octane gas (Mobil /Exxon). No fans. I do use Seafoam every so often. There is a high idle. I let it warm up before I attempt to move it but the car is real cold blooded. I know there is a different cam in it has headers, double pumper carb, electronic ignition, bought that way so not sure exactly what I have. When starting cold, there is no choke, you have to run it, ( pressing gas pedal or it will stall) at about 1300 RPM, after about 5 minutes it will idle down to about 1100 rpm in gear. It's funny because at that point I am backing it out of the garage and it will want to stall. Once I back out of the garage and start going forward it runs fine. It seems very strong to me, sure keeps up with traffic. Very responsive with slight pedal pressure.
Thanks again, John
1 - 20 of 25 Posts
