1 - 10 of 10 Posts
Im running a very mild 355 in a race only foot brake car. It have stock SR torquer heads, RPM intake,650 dp and the smallest solid lift comp cam they make. I want to keep the heads, carb and intake the same along with the 5500 red line. What would be the best upgrade for the dollar, a small hyd roller cam or a 383 short block with a slight increase in solid cam? looks like the dollars spent will be close both ways.
383 and a solid cam.
If you do the 383, maybe you could put some compression in it and pick up ?
Kinda what i was thinking, thanks
What is the rest of the combination? More convertor and rear gear could help you out without touching the motor, depending on what you have now.
the car is spot on the way it is, the driver, thats me, tends to red light. Im just looking to the future.
more converter can help you adjust your lights:thumbsup:
1 - 10 of 10 Posts
