Hello, I'm in a bind here. I have a 12 bolt Moser rearend with Baer rear disc brakes. The original caliper brackets Baer sent me won't work. So I call Moser, they said I had to call Baer and get a different bracket. I get the brackets from Baer at $85 pair. Now I'm supposed to have them counterbored. Seems to me they should come counterbored. Also, I don't know to much about these rear disc setups. I have included tow pics. If you look at the rear the pinion is level. The brackets in one position also sit level. If you turn the bracket around the brackets sits at a higher angle in the rear. It is a Moser 12 bolt with the Ford bearing 3.150 Does anybody know the exact measurments on what the counterbore should be? And can you please tell me by the pics what position the brackets should be in. I would really appreciate any help, thanks, Clyde
