1 - 2 of 2 Posts
Okay, I didn't see about the goodmark brackets before I bought the $20 ebay specials.
What can I do about the front outside holes? Maybe a long bolt with washers in the stock location?
About the stock outside locations, I had seen people movingthem inward about 1 inch to clear the seatbelt. However, I know buckets have different belts. if i am plannning to go to bucket seat belts, do I need to move them? I guess my question is, did GM use the same mounting locations for bench and buckets or did GM put the buckets farther in?
I went with non-factory buckets, but ended up using the original bench seat holes for my adapter/spacer. I used holes in my adapter that were closer together (right to left) for actually mounting the seat rails. I am also now discovering the seatbelt situation. The outer retractable part is a bit too far forward. I've thought about simply moving them back, but was concerned about proper bracing etc.
I'd be interested to find out what alternatives others have come up with.
1 - 2 of 2 Posts
