1 - 13 of 13 Posts
I`ve been looking at front end stuff until i`m now blue in the face. Can someone just recommend where to buy a complete rebuild kit in Moog or Dana/Spicer. I see this problem solver talked about, what is that? I would like to buy a complete kit and save a few bucks if i can. Thanks. Bill :sad:
Moog and Dana front end parts are top notch companies whose products are made to last not like "off brand kits "that use parts from every where..... By going with a name brand you know that you are doing it right because they are made safe and made to fit properly !!!!
(Moog Problem Solver units have been updated with special knurling on ball joints to retain properly and use heavy duty rubber boots )
Does this mean that you sell a kit? I have always had good luck with both brands. Thanks. Bill
Come on guys, i will need these parts soon and i don`t want junk on my car. I know someone out there has bought this kit or just the parts from somewhere. If nothing else, a list of part numbers would be great. Bill
Sorry no part numbers but I know that rockauto.com seels the Moog parts NAPA also sells the parts the drawback is from anywhere that I've seen these parts is there is not an all-inclusive kit or package, you have to buy them individually.
Good Luck,
bob
· Banned
Rock Auto
you can get
Upper Ball joints
Lower Ball joints
Centerlink
Outter Tierods
Inner Tierods
tie rod sleeves
Idler Arm
around $340 from Rock Auto......
I just finished my install, I went all Moog(frontend) with the Black Polygraphite bushings and sway links..... I bought the extra bushing lube and greased the hell out of em...... Took it to NTB had them do the front end alignment...... Man it is like night and day...... Nice and tight.... Not bad with the low profile tires.......
Bill,
Give us a call at (800) 247-2288. We have a complete Front End Kit for the Chevelle in both Polygraphite and rubber.
Our Super Kits include:
* 2 Upper Ball Joints
* 2 Lower Ball Joints
* 2 Outer Tie Rod Ends
* 2 Inner Tie Rod Ends
* 2 Tie Rod Adjusting Sleeves
* 1 Idler Arm
* 2 Upper Control Arm Shafts
* 4 Rubber or Polygraphite® Upper Inner control arm bushings
* 4 Rubber or Polygraphite® Lower Inner Control arm bushings
* 2 Rubber or Polygraphite® Sway Bar Bushings (for most models)
* 2 Stabilizer Links (Bolt and sleeve type links only)
* Control Arm Bumpers (for most models)
The Super kit in rubber is $369 and the Polygraphite kit is $419.
All of our parts are shipped FREE to the 48 US States. And we offer an additional 10% discount to Chevelles.com members!
1 - 13 of 13 Posts
