I'm having a hard time finding information to diagnose a problem with my garage heater and thought maybe there might be some Heating and Cooling guys that might be able to help. A couple of days ago the heater in my shop was working fine and I shut the breaker off to it after it shut itself off and when I came back the next day to turn it on it wasn't working.
When you turn the breaker on normally you hear a couple of clicks like relays pulling in and then you hear a continuous clicking from the igniter firing about every 1/2 second until you hear the main burner come on. Right now all you hear is the initial click and there's no firing from the igniter. I think the ignition control module turns the pilot and ignitor on at the same timeand when the flame sensor reaches temp turns the gas valve on. So basically I have no ignition. As long as I have power and a signal from the thermostat I would think bad module or possible grounded igniter. I was hoping somebody might have an idea thinking about ordering some parts to have on hand so I can fix this thing when I get back in town
