I have a B&M Pro stick shifter in my car that uses micro switches for the neutral safety and reverse lights:
www.holley.com
The first set lasted about 15 years. I had to replace both switches about 2 years ago and now they've failed again. At least they seem to fail closed, so the car will start (in any gear mind you), but now the reverse lights are on constantly.
I'd rather not spend $15 per switch just to have them fail again. Has anyone run across a good quality micro switch that will last? Maybe a different way of wiring them? Currently (pun intended) the micro switches are in series with the stock console shift wiring harness. Basically cut the end off the harness that used to connect to the stock shifter switch and connected these wires to the micro switches.
B&M 80609 B&M Micro Switch for Pro Stick, Pro Bandit and Magnum Grip
Neutral Reverse Micro Switch APPLICATIONS: For use with 80701/80702/80706 Pro Stick, 80793/80794 Pro Bandit, 81040/81041 Magnum Grip, 81045/81046 Magnum Grip.
