1 - 12 of 12 Posts
I have a Mercury Marine 454, that is from a fresh water boat. It suffered a connecting rod failure, on one cylinder, does it have any value to be rebuilt as a car engine or it that a waste of time.
That depends on how much damage was done from the rod failure. If the only issue is damage to the crank, replace the crank and find a replacement rod - do not re-use the damaged one. If it put the rod through the side of the block - not worth rebuilding!
Super Moderator
Depends on what you mean by "fresh water". In the marine world that means that the engine itself had antifreeze running through the cooling system. If it had "river water" running through it then it is probably pretty corroded inside and not worth messing with.
Also depends on what damage was done when the rod let loose.
Bingo!! The water jackets get eaten up by raw water cooling. We had salt water engines that the flakes wouldn't stop falling out of the water jackets. Every time we turned the block more rust fell on the shop floor. When I worked at the machine shop, unless it was closed cooling systems, boat engines, stayed boat engines.
Besides the corrosion potential
If it's from a twin setup - I "think" the right (starboard) engine rotates backwards. do not know how that effects the wear in the engine.
I myself have rebuilt a couple of Marine 454 blocks years ago, being in Michigan it is fresh water and had no issues with rust scale in the blocks. My experience has been the cylinder walls are thicker and there us usually extra nickel in the casting to help prevent some corrosion. Like any block, have it checked before you spend money on machining, it can save you! I just had what appeared to be a very nice standard bore 400 small block I was going to rebuild for my Laguna, ended up having about an 8" crack in the water jacket near the lifter valley and went into the lifter valley - the money spent to check it out saved me a lot more in machining costs that would end up being scrapped!
Super Moderator
Absolutely no difference between a marine block and a truck block. They are exactly the same.
This hasn't been true for quite some time, they now both turn the same direction...unless, of course, it came out of an old boat.
Yeah, the lower unit of the outdrive setup is where the direction is determined to be stardard or counter rotation, not the engine itself.
Aside from corrosion of raw water cooled engines, is there any other reason to stay away from "marine" blocks to put in cars? Big Block marine engines seem to be a dime a dozen in my area.
Not necessarily we put a SBC marine engine in a Ski Sanger that wouldn't run and it turns out it was a reverse rotation engine the shipper sent the wrong one . We had to pull it out a return it for the correct rotation . Google it they come up pretty quickly .lol.
Discussion Starter #11
Based on all the comment I will just toss the lot of it into the trash. I was tired of moving it around in the garage always seamed to be in the wrong place. Thanks for the replys
Guy down the road from me was an engineer @ Mercury Marine,he's got a "66" SS that he bought new,he's got a 502? that was a test mule from when Merc Marine first started using them installed in the car,kind of an interesting story. I've seen the car several times @ his storage building,but have never seen it on the road.He's also got a nice "69" Camaro SS that he also bought new and a "67" Barracuda Notchback with a new Hemi drivetrain in it,all three cars are black and nice.
1 - 12 of 12 Posts
