I have a zz383 and was told I need to run a melonized dizzy gear.
So I went to local GM dealer got a gear and it will not fit my Mallory Unilite distributor pn 4748201. ( the hole in the gear in drilled on center and the hole in the dist. shaft is not, its at an angle)
GM says "run a melonized gear "
I called Mallory, they said there shafts are drilled at an angle not to worry & I don't need the melonized gear "there gear is fine to run with stock roller cams" but when I asked the tech at Mallory to give me his last name he refused.
Has anyone else ran into this?
