i havent used one yet but pro engine builders i know are very impressed with the quality and performance so far. i guess the design is really good at reducing cavitation and supplying a smooth pressure supply.
I'm sure they're great.....but my Melling HV pump has always worked great at speeds up to 7500 and even 8000+ sometimes. Bearings look perfect. I tightened end clearances and that's about it. Not sure that was necessary but makes me feel good.
This would come way after making sure I had the best pan available.
Perfect solution to a non-existent problem? Again..gerotors are fantastic and I'm sure you can improve on a cheap spur gear pump,,,,,but when do you need it?
JIM
