I am doing a auto to manual conversion on my 68 chevelle. The car has been hacked on pretty bad. The brake pedal assembly master cylinder push rod was basically a long rod with a hole drilled in the end and bolted to the brake pedal arm and shoved into the hole of the master cylinder with no adjustment. Where can I find the correct push rod? I have poked around on the net but I haven't found one yet.
Also I have the pedal assembly but not any of the zbar or clutch linkage stuff where would be a good place to find this stuff
