1 - 11 of 11 Posts
I searched the archives but couldn't find an answer.
Here is how I currently hooked up the wiring:
My problem is I keep cooking the toggle switch (35 amp) The wiring (all 10 gauge) only heats up at the toggle switch, nowhere else. If it is wired up ok now, do I just need to step up to a bigger toggle? or is there another way to do this?
I need to keep it hooked up with a toggle switch because I don't have the money to use one of those fancy thermostatically controlled switches.
BTW - this fan rocks! It keeps my 406 at 180
- pun intended
WEBSITE UPDATED 03/18/02
Adam Layman
1971 Chevelle Malibu
My website
[This message has been edited by AdamLym (edited 04-16-2002).]
Discussion Starter · #2 ·
-OR- Would it be better to wire in this relay instead...
Mfg. P&B
Mfg. # VF4-45F11
1" sq x 1"
SPDT, 12 VDC @ 40 amp
Coil resistance: 90 ohm
With bracket.
It is only $3.25, perhaps this is a better option? Would it be what I need to keep from cooking the switch?
Adam Layman
My website
WTF, where did my post go?!?!!?
this **** is getting on my nerves.
-what you have is bad. fire hazard bad.
-what you need is a relay.
-do you still have the diagram I sent you?
71' 3880# with me. Big Block 402, Merlin oval heads, 10.2:1CR, TH400, 3.73 posi,
1/8th: 8.0 @ 88mph
BEST 60': 1.85 w/street tires.
BEST 1/4: 12.5 with 1.89 sixty foot (street tires)
BEST MPH: 109mph
Picture of me roasting the tires and other guy stuff
Video of me staging (smoke of course)
OK guys, so you don't like my wiring eh?
lol
I ordered up one of These
Yeah, I have your diagram at home Mike, I just tried to adapt it to use the wrong type of relay
Hopefully UPS will have the relay to me by the time I get home friday
Thanks guys!
Adam Layman
My website
ANY time a wire or switch gets hot, that means it can't handle the current that's flowing through it.
I put a DC Amprobe on my Mark VIII and found it was drawing 38 amps. So a 40 amp relay should theoretically carry the load.
I run two 30-Amp relays in parallel. Some people don't believe in this, but at $1.99 each they,ve served me well for almost two years now. I use a rocker switch to activate the relays.
Just because you're not on the "hot" side of the circuit, doesn't mean that there's no current flow.
Follow my advice and others and use relays to wire the thing.Keep the heavy loads outside of the passenger compartment.
My Web Page (updated 3-19-02)
"America will endure!"
Chad Landry
TC Member #643
ACES Member #04556
'68 El Camino, 357, L31 Vortec heads, 700R4, 3.55 posi.
<BLOCKQUOTE>quote:</font><HR>Originally posted by BB_Mike:
<HR></BLOCKQUOTE>
What post? Nobody has been in here wacking posts.
Adam
You need and off/on switch. Think I have an extra toggle switch that will work the relay. Send me your address.
[This message has been edited by John_Muha (edited 04-16-2002).]
If yur ordering a relay you should also get the relay connector or base and the wire terminals that are the capture type for the base. 2-50F1001and 2-50F1002are required.
Note: that the line and load connections of the relay are larger than the relay coil connections. The standard crimp on tab terminals will not fit.
Thanks Elree - ordered them up too, too bad I didn't order it all at once though, the charge a $5 service charge for unders under $25
DOH
Oh well
Thanks again!
Adam
Adam Layman
My website
1 - 11 of 11 Posts
