Hey fellas,
I am setting myself up to tune a Holley 4bbl carb with the Innovate wideband 02 and SSI-4, TPS, and a MAP sensor. I actually did this about 10 years ago, but sold off my entire set up (I'm an idiot....). I had drilled/tapped all the fixed orifices in my carb and created my own brass jets for those spots and reallly-really-really had it dialed in. I moved from 2200ft elevation down to 700ft and wanted to dial things back in.
I can't find any info on the previous MAP sensor I used. I was wondering if any of you guys can recommend a MAP sensor in which you have the calibration data for - i.e. voltage output per in-Hg. I was thinking the easiest and most readily available would be something from an LS1 or such.
Any help/feedback is appreciated.
Thanks,
Jay Chekansky
Thanks,
Jay Chekansky
