1 - 2 of 2 Posts
I want to change to a manual trans. Right now I have a th400 on the column. I can get a st-10 but what other parts do I need to make the change. I dont mind cutting a hole in the floor.
Last time I did this I used a M21 that had the same output shaft as the old TH350..so I didnt have to switch yokes and the crossmember worked also..not sure if the super T10 has the large output of the TH400, if not you will need a yoke. Then you need the clutch and brake pedal, z bar, rod from clutch pedal to z bar, rod from z bar to clutch fork, as well as the bellhousing, clutch assy with throwout bearing and fork, and pilot bearing...ok what did I forget?
70 chevelle ss396 conv
66 chevelle ss396 hdp/conv
55 chevy prostreet
1 - 2 of 2 Posts
