1 - 8 of 8 Posts
I'm swapping from a manual to an auto and I have a center console. Is there anything different about the shifter hump from manual to auto?
Sent from my iPhone using Tapatalk Pro
yeah, usually there is due to the shifter location on the manual set up, there will be a pronounced hump to the left side of the transmission tunnel where the shifter passes through the floor. Shouldn't really cause you an issue though as you are going from manual to auto, just a hole to cover....
Gold Founding Member
It sure does help if you give an indication of what year car you are working on.
Did I read this right or do I have dyslexia, man to auto?, just kidding I think you can buy a blank off plate from somewhere like NPD, Ground Up or one of the other vendors, are you removing the pedals too?
Yes I'll install the correct pedals. The gas pedal is being swapped out for a drive by wire version for the LT4 being installed. The brake pedal I'll want the correct wide version.
theres a hump on the tunnel on a original manual trans car. You might have to drill out the rivets and remove it to allow the staple shifter to sit properly on the tunnel so your console can still bolt to the shifter mount. Other than that, youll need the top plate and shift plate. the base of the console will work. jim
There are two different humps, one for the console, and one without. If you have a centre console, your fine and it will sit in exactly the same position.
1 - 8 of 8 Posts
