I am at the point to run some vacuum lines. I have power brakes, A/c, Th350 trans. and Cowl hood. Ground up offers 3 fitting for the port on my manifold behind the carb. ( booster(3/8") , 1 vacuum line or booster 2 vacuum lines and booster and 3 vacuum lines).
I was planning on putting the booster and trans. together.
Where to put cowl vacuum line and A/c vacuum line at the same point or not? If so I will go with the 3/8" x 3 vacuum line correct? Am I missing anything?
Thank you for the help again
Dave
Dave
