I picked up a used one and was wondering how to wire it in. There is a red,brown, and green wire. Anyone have any idea?
Super Moderator
http://www.mrgasket.com/malinst.htm
Make sure and read all the directions completely, especially the part about needing a resistor wire, or ballast resistor.
Hope this helps,
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
The three wires you discussed go directly to a coil made for that dist. ( High energy one ) You then wire the coil direct from the existing wiring harness. Check the wire for voltage. It should check to be around 9 volts. If it checks 12 volts, you'll need a resistor between your 12 volt feed wire and the coil.
[This message has been edited by Tim Tate (edited 03-19-2001).]
