Well, I'm not getting any spark so I decided to test the module, here is some info.
Mallory Unilite Wiring:
Red wire goes to pos. side of coil
Green wire goes to neg. side of coil
Brow wire is a ground to the engine block
When I hook up 12v to the red wire and test at the green with the ground hooked up I get 0 volts when open. When I close the module (with a credit card to block the optics) it reads 1 volt.
-and-
12v to red wire, NO ground, test at green wire I get 12v, but as soon as I ground the brown wire it drops to zero.
Any ideas?
Do you run a balst resistor?If not that's how I toasted two of those :(needs to be under 12,like 9.6 ,12 volts works for awhile. :eek:
Yup, i run a ballast resistor. Brain fart for listing the above voltages at 12, they were around 10 (analog meter)
Acording to unilight test procedure:
The voltage should drop to 3 volts or less
[1 to 2 volts].If thist test is positive,then the module is working.
Got that at mallory ignition some where.
Yours won't start mine won't shut off.I don't know what's worse?
Got mine going
hope you got your's going Adam
