Hi Guys,
It has been a while since I posted here in the LSX Section.
Way back in 2012, I purchased a 20,000 mile LY6, 4L80, and a LSA Supercharger.
Below is a list of parts that I used and a few options for your build.
The Brian Tooley Racing items are of amazing quality. I strongly recommend them for your LS needs.
12633906 ~ Chevrolet Performance Loaded Timing Cover (Individual Components Listed Below)
12600326 ~ Timing Cover
12585673 / 296-02 ~ Engine Crankshaft Seal
12633904 ~ LS Timing Chain Cover Gasket (LS1, LS2, LS3, LS6)
AC Delco GM OE Camshaft Position Sensor 12591720
645-526 ~ Dorman Wiring Connector
12599296 ~ Chevrolet Performance Valley Cover Found on Production LS3 & LSA Engines
12588670 ~ Chevrolet Performance Timing Chain Dampener
12646386 ~ LS9 Timing Chain
12586481 ~ 3 Bolt Camshaft Timing Sprocket
12638427 ~ LS9 Camshaft
12499225 ~ Chevrolet Performance Hydraulic Roller Lifters
12595365 ~ Chevrolet Performance LS Valve Lifter Guides
12622033 ~ LS9 Head Gaskets
19180613 ~ Engine Intake Manifold Gasket Set
PR7400312-16 ~ Brian Tooley Racing One-Piece Pushrods
BTRTK001 ~ Brian Tooley Racing Rocker Arm Trunnion Upgrade Kits
OR
BTRSRKR3KIT ~ Brian Tooley Racing LS3 Unassembled Shaft Rocker Kit - No Rocker Arms Included BTR LS3 SHAFT ROCKER KIT (briantooleyracing.com)
BTRSK001-16 ~ Brian Tooley Racing Platinum Dual Valve Spring Set
10295 ~ Melling Performance Oil Pump
ARP 134-1003 LS Cam Bolt Kit Chevy GM Gen III/LS Series Small Block Hex
ARP 234-2503 Crankshaft Harmonic Balancer Bolt
ARP 134-3610 Pro Series Cylinder Head Bolt Kit ~ 2004 and Newer
OR
ARP 234-4319 ~ Pro Series Cylinder Head Stud Kit
ARP 244-2901 ~ Flexplate Bolt Kit
ARP 230-7305 ~ Torque Converter Bolt Kit
ARP 434-1202 ~ Stainless Steel Header Bolts
ARP 234-6301 ~ Cracked Connecting Rod Bolts
12637686 & 12637688 ZL1 Valve Covers (The Truck Coil Brackets caused clearance problems)
12604630 ~ Water Pump
12634547 ~ Dipstick
12625031 ~ Dipstick Tube
HLY-302-2 ~ Oil Pan
AC Delco PF48 Oil Filter
551910 ~ ICT Billet Oil Pump Pickup Tube Braces
399754 ~ TCI Flexplate
L960202012 ~ Lingenfelter Solid Isolator Coupling
12622236 ~ ZL1 Lid
P-150035 ~ PCM of NC ZL1 Brick Reinforcements
918854 ~ ATI Super Damper
916106 ~ ATI 10% Overdrive Pulley
918993 ~ ATI Crankshaft Pin Drill Fixture Kit
ACC Performance Boss Hog Torque Converter Boss Hog Torque Converters | High Performance Torque Converters
PSI Conversion (Performance Systems Integration) PSI | Standalone Wiring Harness | LS Wiring | LS Wirng Harness | LSX Harness | LSX Swap Harness | LS | LSX | LS1 | LS2 | LS3 | LS7 | LSA | LS9 | LT1 | Vortec | 58X | 24X | Swap | Conversion
LSX Concepts LSA / ZL1 Supercharger Race Drive High Accessory Mount Kit (Alternator, Power Steering, Air Conditioning) This Kit used the Sanden SD709 Compressor
Who would have thought this much planning is involved in installing a LS?
I hope that this list serves as a guide for years to come.
If anyone has any questions, please send me a PM. I am happy to help.
OR
OR
12634547 ~ Dipstick
HLY-302-2 ~ Oil Pan
12345982 ~ AC Delco Supercharger Oil (2 ~ 4 ounce bottles are needed. Supercharger Capacity is 5.1 Ounces) |
12622236 ~ ZL1 Lid
LSA / ZL1 Supercharger Race Drive High Mount Accessory Drive (ALT,PS,A/C)
ZL1/CTS-V LSA Supercharger Race Drive 8 Rib Accessory Drive (Complete Kit) Perfect for installing your Camaro ZL1 / CTS-V Supercharger, Camaro ZL1 / CTS-V LSA Supercharged Pullout, Chevrolet Performance 19257456 E-ROD LSA Supercharged 6.2L 376ci Engine, or custom built LSA Supercharged engine in...
www.lsxconcepts.com
