1 - 10 of 10 Posts
I've been doing some research on this cam and been reading that you need a 1/2" in Fuel line from the tank and 170 GPH Fuel Pump?, i kinda think maybe this cam is a little too big for my build, for those that are running this cam what size of line and fuel pump are you running?
Boldly procrastrinating
UDHarold designed those lobes. He recommends 1/2" fuel lines for engines with his more aggressive cams.
I run the next size up, the 60213 with a holley blue pump and 3/8 line from pickup to carb.
Beaten to death subject...
Worry about 1/2" line when you break into the 10's - DEEP 10's
Did you buy this cam?
No i bought the 60211
I have a 60212, and I have a 170gph pump, but currenty use -6 AN lines. I have not noticed it nosing over on the high end at all.
Can you post your current setup? Engine Components? Rear? Trans? HP/Torque?
Where did you buy everything?
1 - 10 of 10 Posts
