Finally pulled the cam out of my 496. I discovered it is an everwear core and has the black pressed on distributor gear. Lunati told me they could regrind it for $125 with a few days turnaround. Now I need to decide on what to tell them. I want my power brakes back and low end thump. A lot of professional on here have suggested cam profiles and I appreciate that. If I can make this cam work with a regrind it will save a little green. Also, it is a gen 6 step nose. The crank gear is in the 2+ groove and the chain has slop in it like a bicycle. Is that normal?
420 Megablower 8-1 496
Edelbrock Perf RPM rectangular port bowl blended heads 121cc
flat top pistons
Lunati hyd roller custom grind 114lca 109icl 240/245 @ .050 .647 lift
Dual 650 Holley dp carbs manifold ref with QFT block and 4 corner idle
MSD 6al locked dist at 32 degrees
TKO600 4.11 gear 29" tires
idle 1000rpm 10" vacuum
Cruising in 5th at 2000-2200rpm 14" vacuum
flat top pistons
