in other words, no. once you get the work done to make them work, you could have bought a nice set of aftermarket heads that make more power.ss,
The LT1 heads will bolt on, but they will not work unless you weld up some cooling passages and add some other ones. They are designed for the reverse cooling system on the LT1's.
