If you are good with a welder can get it welded and machined fairly cheap,then it can be done because I have done it myself.You will have to figure how to route the coolant to the thermostat(I did it with a pipe from the front of the head to the intake)and then if you do not get enough flow it will run about 210 degrees.But these heads will run extremely good with a mild motor.But you can get the cast iron vortec heads for about $400 and run almost as good just a little less compression because of the bigger combustion chamber but the intake port in the vortec is more desirable than the LT1 head but the exhaust port needs opening up to flow with the intake side.They are the better value and they're cheaper and new,not off of another engine.
My $.02.
John 67SS
ACES #2887
[This message has been edited by 67ss (edited 04-16-99).]
